Re: bleach calc
mwsmith2
Enter your pool size in gallons. Enter the bleach strength as a whole number, enter 6% as 6. The strength of your bleach should be on the side of the bottle. It'll generally be either 5.25% or 6%.
Next you have to know how much increase you need. If your pool is at 0 PPM Cl and you want to get to 5 PPM, put 5 in the box that says "PPM increase desired". Click calculate. The box that says "bleach required" is how much bleach you need to pour in.
Run your filter on "filter" not recirculate. Won't do you much good otherwise!
Michael
I downloaded your bleach calculator.. you are saying enter "gallons".. the calc. says "L".. is that litres or gallons?
Chuck
Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
