Thread: CYA reagent refill instructions?
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Question CYA reagent refill instructions?
    I have a PS 233 kit. My original small bottle of CYA reagent is empty. I haved the larger refill bottle that came with the kit. It says to see the website for refill instructions. I can't find those anywhere on the PoolSolutions site.
    What do I need to do in order to test CYA again? Do I need to dilute the reagent refill or do I use it straight?
    Thanks in advance!
    Salinda
    Default Re: CYA reagent refill instructions?
    use it straight-it's just a larger quantity than will fit in the kit. Use it to refill the smaller bottle.
