Results 1 to 10 of 10
Thread: Water Evaporation
    Default Water Evaporation
    Just curious as to how much water is lost to evaporation.
    I'm in NJ and we've received almost no rain in the past 10 days. In the same 10 days my kids have not been in the pool and I've lost about .5-.75 inches.
    Is this a normal rate of evaporation (my filter is on for about 14 hrs mostly at night) or do I have a leak in my new liner .
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Default Re: Water Evaporation
    That sounds normal for me.....especially when we have hot DRY temps....
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
    tough to say, sounds pretty normal, especially when hot dry and windy, however, if you suspect a leak, it is in your best interest to do the bucket test so you know for sure.
    It sounds about right--I've lost closer to 2" in the last week or so, but we haven't had rain in over a month and the air temp is 100-104 for the past week...
    Poughquag, New York, USA.
    Same here. I'm in lower NY. Lost about 1 1/2 to 2" in the last 2 weeks without rain. (Got an inch back yesterday due to nice overnight rain). That's why I started using my solar cover again.
    kevincad is offline Registered+ Thread Analyst kevincad 0
    Snellville, Georgia, U.S.A..
    Quote Originally Posted by Ken S
    that sounds about right to me. You can cut that down a lot with a solar cover.
    San Antonio, TX
    I started worrying if we had a leak too because it seemed like the level is down every few days by about an inch. My wife assures me it's simply evaporating because it's been 100 degrees almost every day, it's only rained-rained once (and for only 10 minutes) in about 3 months and our backyard is always windy. As hot and dry as it's been I guess it is just normal evaporation.
    Scottsdale, Arizona
    You should see how fast it evaporates in Aridzona
    I second that from Arizona.
    Your evaporation sounds fine to me.
    Dennis
    Honesdale PA
    Ken,
    Sleep well, enjoy the pool, don't be concerned. I'm in Northeast PA and see similar numbers.
