Thread: White Film / residue floating on top of pool.
    Jul 2006
    Default Re: White Film / residue floating on top of pool.
    I've been using the bleach as chlorine and it was liquid Algaecide probably put a little too much in not sure what to do now.
    mbar's Avatar
    Ashland, PA
    If it was the algaecide, then it will go away on it's own, bump your chlorine up and it should clear faster.
    Northeast PA
