Thread: Light brown deposits after shocking?
    pool newby is offline ** No working email address ** Thread Analyst pool newby 0
    Default Light brown deposits after shocking?
    About every two weeks , I add a bag of Cal-hypo to shock my 8600 g 18' ABG, mostly because I have several bags left over from the pool store. Normally, just use bleach to chlorinate. I premix the cal-hypo well in a bucket of water before adding, and continue mixing the settled portion until its all mixed well. Of course, the water clouds up for a day. However, always on the following day, I have several little deposits of light brown residue all over the pool, that I vacuum up. If this is cal-hypo, why is now brown , instead of white? Could it be something else, like algae, even though I've had no signs of algae before ?
    thanks
    Bob P
    pool newby
    8600g, 18', Pacifica, 26" High rite sand filter, 2.5 hp two speed pump
    mbar's Avatar
    Ashland, PA
    Default Re: Light brown deposits after shocking?
    If you post some of your numbers:
    Free Chlorine
    Combined Chlorine
    PH
    Alkalinity
    Calcium
    CYA
    When we see where your water is, we can help determine what is going on.
    Northeast PA
