Results 1 to 10 of 14
Thread: CH = 400 too high for a new gunite/pebble pool?
    joelq is offline Registered+ Thread Analyst joelq 0
    Frisco, TX
    Default CH = 400 too high for a new gunite/pebble pool?
    Hi all - we have a new 12000 gallon IG with SWG, started on August 1st. I've been testing at least once each day with a Taylor K-2005, and below are my numbers as of 30 minutes ago:
    FC: 4
    CC: 0
    TC: 4
    pH: 8.0 (as it always is in the morning, so I have to add 40 oz of muriatic every morning).
    Alk: 90
    CH: 400
    CYA: 55
    Salt: 2900 (according to the Aqualogic PS-8), 3200 (according to Taylor salt test kit)
    I noticed that my CH has risen since start-up (was 140 at startup, 350 ten days later, and now 400.) My Aqualogic manual says the range for my CH should be 200-400, so now I'm at the high-end of that.
    I've read many posts saying it's bad to have too low calcium for a gunite pool, but what happens if it's too high? Is 400 too high? What's causing it to keep rising?
    Thanks everybody!
    Mandeville, LA, USA.
    Default Re: CH = 400 too high for a new gunite/pebble pool?
    It's the plaster dust coming off the new plaster that's making your CH rise. It's probably not a problem at it's current level but may become one (can cause scaling) if it goes much higher (especially at higher pHs like you're seeing). It sounds like your fill water is relatively soft though, so if need be, you'll be able to do a partial drain and refill to lower CH once your plaster stabilises.
    Edit: Joel, I just re-read the title of your thread. Do you have actual pebble-tec or one of the knock-offs? It was my understanding that pebble-tec does not leach calcium.
    Frisco, TX
    Hi Kurt - thanks for your reply. We have Stonescapes (and not PebbleTec).
    Joel,
    I'm not familiar with that particular product but I'm guessing that it is plaster based and is the cause of your rising calcium hardness. Have you asked the builder or plasterer about it?
    North Florida
    Question Re: CH = 400 too high for a new gunite/pebble pool?
    Any chance you were using calcium hypochlorite as your chlorination source prior to your SWG going online?
    Sandy
    Frisco, TX
    Kurt - I haven't asked the builder yet, but I guess that's the next logical step. I'm guessing though that Stonescapes isn't plaster-based as they have taken the pebble all the way out of the water for our beach entry. They also gave us an option not to do waterline tile specifically because of this reason (although we went with water line tile to have that "finished" look). Wouldn't plaster have to remain underwater?
    DawnDenise - I was using bleach exclusively prior to firing up the SWG, so no calcium hypo.
    Thanks!
    Joel, According to NPT's website, StoneScapes is plaster based.
    Quote Originally Posted by joelq
    Thanks everybody!
    Scaling can be a problem as was mentioned above and also you may have trouble with cloudy water.
    A few things don't make sense to me about what's going on here. If the source of the rising calcium in the pool water is coming from the pool surfaces, then this should slow down and stop when it reaches equilibrium. With the numbers posted, the pool water should be in perfect balance at a pH of around 7.6 and at 8.0 the pool water should already be over saturated with calcium carbonate. I can understand the initial rise from 140 to 350, but do not understand why it is continuing to rise.
    The other piece of information that does not makes sense is that adding 40 ounces of Muriatic Acid to a 12000 gallon pool with a TA of 90 and CYA of 55 should result in a drop in pH from 8.0 to 7.12 -- is that what he is seeing? So the pH rises from 7.2 to 8.0 over 24 hours and creates a daily acid demand of 40 ounces of Muriatic Acid every day? This seems extraordinarily excessive to me and since the TA is already somewhat low (a good thing to avoid carbon dioxide outgassing), it would appear that there is an additional strong source of base in this pool. I suspect that the SWCG system is somehow faulty and possibly not dissolving the generated chlorine gas into the water properly, though it would take generation of 6.5 ppm of such chlorine per day to explain the numbers (and that seems too high).
    Are the posted numbers correct? Especially the 12000 gallons and 40 ounces of Muriatic Acid daily?
    Richard
    Saint Cloud, FL
    I think there is a combination of things occuring here that are creating high pH and high CH.
    The aggregate is still curing, and causing the pH to rise. With a pH of 8, the SWCG is at its minimum output regardless of the output setting. Therefore I can well understand the 40 oz of acid having to be added each day at this stage of curing, but in this case it does seem excessive. However the SWCG is still producing 4 ppm Chlorine, so as Richard says, something is out of whack.
    I have just been going through this with my Diamond Brite replastering in my 20,000 gal pool, which may not be quite the same as Joelg's Stonescape. Not being familiar with Stonescape, it may be that the leaching occurs faster with this product.
    Another set of numbers from a pool store might help to qualify the initial set.
    Pat
  1. Calcium Hardness in Pebble tec pool
    By dubbedout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2013, 11:10 AM
  2. Cracks on Pebble Pool - How to repair?
    By clueless702 in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2013, 11:35 PM
  3. Gunite already calcium deposits and small hairline cracks of both plaster and gunite
    By getittogether in forum In-Ground Pool Construction and Repair
    Last Post: 04-10-2011, 01:45 PM
  4. New pebble/SWG pool - when can I add salt?
    By joelq in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-07-2006, 02:44 AM
