Results 1 to 10 of 10
Thread: Autopilot
    Default Autopilot
    Hi, I have an Autopilot with a 48 cell. I am getting a RED light flashing all the time saying check/clean cell.I have cleaned the cell and still get the same flashinging red light.I have also tried rebooting the unit.What should I do in order to correct this problem. I do notice when the cell turns on the red light stops flashing. Thanks for any information you can provide me.
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Re: Autopilot
    Started my system up and have the same indication. Ran the Test Poolpilot function and cell reads 29volts, 4.4 amps. Everything ran fine last year.
    Ft Lauderdale, Fl
    Please verify your salt levels and for any scale on the cells. Increasing the salt to about 3500 ppm, especially in cold water conditions should compensate by increasing the conductivity of the water. If you have additional problems, please contact the factory.
    Sean Assam
    Jersey Shore
    Thanks Sean, you nailed it. I added salt and got it up to 3000ppm, but the water temp. was only 65.
    Ft Lauderdale, Fl
    Bring it up to 3500 ppm and it will run even better for you, especially under the cold water conditions. You won't even notice the additional salt in the water.
    Sean Assam
    Cedar Hill, TX (Dallas)
    funny, I had the same problem on my 48.... called support, they said increase salt, and that fixed it! (I was 2800 before I started)
