Re: Pump Size
Poolman1, is a 1.5 horse dual-speed likely to be a good candidate for a 32,000 gal. in-ground pool too?
I have two motors, both of which are on their deathbeds. One is a 1 horse, one is a 2 horse (but with an impeller that says 1.5 horse). Pumps are old UltraFlow, installed by Sylvan in 1991. All plumbing is 1.5", except (curiously) for the final return to the spa, which is 2". The pool filtration circuit passes through a Titan stainless steel 60 sf filter and a new Sta-Rite heater.
I had always assumed that the 2 horse was for the pool, but your note suggests that it's for the spa jets. Does that sound right? Everything was unassembled when I bought the house and I didn't know any better.
Is the two-speed a good choice for the pool, with a manual switch just to get high speed when backwashing or doing other maintenance chores? Thanks.
23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
