Results 1 to 10 of 10
Thread: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    Default Re: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    I do know that some of the montly and weekly treatments that are used with borates contain both tetraborates and boric acid or sodium bisulfate (dry acid) so the pH rise does not occur. Proteam's Weekly Treat is an example that contains tetraborates and dry acid but it is supposed to be used in a pool that already has the borates added just to help maintain levels lost by backwashing. Also, Salt Water Magic montly by Natural Chemisty also contains both tetraborate and boric acid for the same reason. I suspect the problem is that boric acid is not that soluable in the amount neededand by itself would probably have negative impact on the ph as well that is not as easy to adjust.
    I just added the tetraborate (borax) and the acid since this is what you would do if you were adding Supreme or Optimizer (or one of the other commercial products) to the pool initially.
    Adding the acid is pretty easy, for each 4lb 12 oz box of borax first put 5 cups of acid into the water and then add the borax....then add 5 cups more acid and another box of borax until you reach the target level. For more precise dosing read these two posts
    http://www.poolforum.com/pf2/showpos...8&postcount=21
    http://www.poolforum.com/pf2/showpos...7&postcount=22
    Just remember to add enough acid first to neutralize the pH of approx 10 lbs of borax added at a time and then alternate adding the acid and borax until you reach your target.
    I posted some info on the other tetraborate thread, but I did find this WHO document full of some useful information. It would appear that, at least in simulated seawater, 100 ppm is more effective in inhibiting or killing algae than 50 ppm, but pool water is not sea water. There seems to be no question that Boric Acid (or its borate ion) inhibit growth of several kinds of microorganisms, but I just find it suprising to see the relatively large drop in chlorine usage that Evan (waterbear) has noticed so far. Most chlorine loss is during the day due to breakdown from sunlight (UV) so to truly cut down chlorine consumption significantly a substance has to prevent this loss. My concern would be that the mechanism for this (if it exists) could be similar to CYA and that could mean a reduction in chlorine effectiveness.
    Also, with regard to adding a bunch of HCl to the pool, remember that the combination of adding Borax and Muriatic Acid gives you the boric acid you want plus salt (NaCl). That is, the end result is nothing nearly as toxic as the original HCl you started with. It's kind of like adding Muriatic Acid (HCl) with Lye (NaOH) to produce salt and water. You can't think of the result of mixing toxic chemicals as producing a toxic result. I agree that Muriatic Acid is a bit of a pain to handle, but using gloves and holding one's breath or looking away should be sufficient precaution (wearing glasses would be an extra safety factor in case of splashing of drops).
    Richard
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    ChemGeek, If you've read my other posts you know that I actually like muriatic acid and get into the pool when I add it. (Goggles on.) My pool drinks the stuff by the gallon. I'm only interested in adding boric acid because as far as I can tell I get exactly the same result without having to use (pay for, measure, etc.) muriatic acid. Call me a purist?
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Talking Re: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    WB, welcome to the forum! As you are new to both pool ownership and the forum, I suggest you read all the 'stickies' at the top of each topic and give poolsolutions a good read. Caring for a pool doesn't have to be hard, if you follow the guidlines here you can all but eliminate the problems that so many pool owners experience. In the future , it might help to post in the correct area, (I see that this one is in the 'bathing suits and loungechair section') as that will allow more people who could answer your question to see it.
    With reguard to your question, I'll have to pass this on to Evan, he's currently conducting an experiment on his own poolwhich almost mirrors your querry. With any luck, he'll know what's going on (he really knows his shi*). BTW, I don't really know anything about pools, but I stayed at a Holiday Inn Express.
    Seriously, thanks to your 'experiment' and comments (findings), I think I'll start refering to Proteam by their rightful name - again, thanks Evan for all you do here and all the great help you provide!! - Ted
    Ted,
    What can I say...I've always liked chemistry sets and now have a 6600 gallon one in my backyard!
    Seriously though, it was your rant on Proteam in the china shop a while back that got me thinking about trying this since we sell the Proteam line where I work. The products in their line that I have used I have been very pleased with (Metal Magic is a prime example) but I had my own doubts about the claims for Supreme (and I distrust ANYTHING Bioguard says!) I really didn't expect the results to be so successful and time will tell if it works over the long haul. Unfortunately, I can't recommend borax at work but I have turned many of my customers on to this forum. The other ones (that just want a magic bottle for their pool problems) I can now recommend Supreme to because I know it will help.
    I've looked at Evan and Richard's discussion regarding the dosage of borax and HCl per 1000 gallons. If they've got their numbers right it would mean a 22,000 gallon pool would require 17 boxes of borax and 5 gallons of muriatic acid. That sounds about right compared to the ProTeam Supreme dosage instructions. But that's more than $100 worth of chemicals. Cheaper than Proteam Supreme but I think I'll hold off for a bit and see if the Waterbear is still seeing good results after a week.
    So, Evan, I've been waiting with bated breath. Does your pool still hold chlorine better than it did before you added Borax? Is the pool still sparklier and less eye-stingy? Can we call this technique "ProBear Supreme?"
    Quote Originally Posted by sailork
    Seems to be
    Yes, the water seems clearer (I can notice it at night with the lights on) and it doesn't seem to irritate. They only way I can describe it is 'sliky'
    LOL....you need to give Richard some credit also...how about "Probear SuGeek"?
    After 6 weeks of 50 ppm borates in my pool I can say that I am satisfied that it does live up to 4 of the 5 claim made for it based on my experience with it!
    1) more stable pH--after 6 weeks my pH seemed to be holding steady at 7.6-7.7 and I put in 6 oz. of acid to drop it back to 7.5 today. Before the borates I would put in 24 oz of acid every 3 weeks to drop the pH after climbing to 7.8 or 8.0.
    2) Algaestatic properties--still unable to determine. Never had algae since the SWG went online and my phosphates are between 2000-3000 ppb. From what I have read and researched this would appear to be true, however.
    3) reduced chlorine usage--seems to be a yes. Have lowered my SWG output to 4% today! After a week at 5% my FC was still 7 ppm. Before the experiment I was running it at about 8%-10% to maintain about 5 ppm FC. Other factors could be at play here but I have not been able to determine them.
    4) silkier feeling water--less skin and eye irritation--although subjective this one appears to be a yes. The water does feel silky and is, IMHO less irritating than before!
    5) clearer, 'sparkling' water--another subjective one but I would have to say yes. I have to vacumn less often and I don't have to change skimmer socks weekly. They are good for 2 weeks now.
    The water is definitely clearer looking when the lights are on at night. Perhaps this is tied in with the lower chlorine demand and the algaestatic properties. I am thinking that if algae doesn't start to grow then less chlorine is used. Perhaps algae is always trying to grow in a pool and the chlorine is killing it and the stuff I was vacumning and collecting in the skimmer sock was dead algae. Would appreciate any feedback on this theory.
    Would I recommend putting borates in the water to 50 ppm? From my experience so far it would be a resounding yes!
    Would I recommend a product like Supreme or Optimizer? No. You can achieve the same results with plain old borax, which is what I did! The cost is considerably less.
