Results 1 to 10 of 10
Thread: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    Default Re: Do borate products (Supreme, Optimzier, etc.)work as claimed?
    Ted,
    What can I say...I've always liked chemistry sets and now have a 6600 gallon one in my backyard!
    Seriously though, it was your rant on Proteam in the china shop a while back that got me thinking about trying this since we sell the Proteam line where I work. The products in their line that I have used I have been very pleased with (Metal Magic is a prime example) but I had my own doubts about the claims for Supreme (and I distrust ANYTHING Bioguard says!) I really didn't expect the results to be so successful and time will tell if it works over the long haul. Unfortunately, I can't recommend borax at work but I have turned many of my customers on to this forum. The other ones (that just want a magic bottle for their pool problems) I can now recommend Supreme to because I know it will help.
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    I've looked at Evan and Richard's discussion regarding the dosage of borax and HCl per 1000 gallons. If they've got their numbers right it would mean a 22,000 gallon pool would require 17 boxes of borax and 5 gallons of muriatic acid. That sounds about right compared to the ProTeam Supreme dosage instructions. But that's more than $100 worth of chemicals. Cheaper than Proteam Supreme but I think I'll hold off for a bit and see if the Waterbear is still seeing good results after a week.
    So, Evan, I've been waiting with bated breath. Does your pool still hold chlorine better than it did before you added Borax? Is the pool still sparklier and less eye-stingy? Can we call this technique "ProBear Supreme?"
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Quote Originally Posted by sailork
    Seems to be
    Yes, the water seems clearer (I can notice it at night with the lights on) and it doesn't seem to irritate. They only way I can describe it is 'sliky'
    LOL....you need to give Richard some credit also...how about "Probear SuGeek"?
    After 6 weeks of 50 ppm borates in my pool I can say that I am satisfied that it does live up to 4 of the 5 claim made for it based on my experience with it!
    1) more stable pH--after 6 weeks my pH seemed to be holding steady at 7.6-7.7 and I put in 6 oz. of acid to drop it back to 7.5 today. Before the borates I would put in 24 oz of acid every 3 weeks to drop the pH after climbing to 7.8 or 8.0.
    2) Algaestatic properties--still unable to determine. Never had algae since the SWG went online and my phosphates are between 2000-3000 ppb. From what I have read and researched this would appear to be true, however.
    3) reduced chlorine usage--seems to be a yes. Have lowered my SWG output to 4% today! After a week at 5% my FC was still 7 ppm. Before the experiment I was running it at about 8%-10% to maintain about 5 ppm FC. Other factors could be at play here but I have not been able to determine them.
    4) silkier feeling water--less skin and eye irritation--although subjective this one appears to be a yes. The water does feel silky and is, IMHO less irritating than before!
    5) clearer, 'sparkling' water--another subjective one but I would have to say yes. I have to vacumn less often and I don't have to change skimmer socks weekly. They are good for 2 weeks now.
    The water is definitely clearer looking when the lights are on at night. Perhaps this is tied in with the lower chlorine demand and the algaestatic properties. I am thinking that if algae doesn't start to grow then less chlorine is used. Perhaps algae is always trying to grow in a pool and the chlorine is killing it and the stuff I was vacumning and collecting in the skimmer sock was dead algae. Would appreciate any feedback on this theory.
    Would I recommend putting borates in the water to 50 ppm? From my experience so far it would be a resounding yes!
    Would I recommend a product like Supreme or Optimizer? No. You can achieve the same results with plain old borax, which is what I did! The cost is considerably less.
