Thread: Pool light repair questions.
    Default Pool light repair questions.
    I'm in the process of changing a burned out bulb in my Amerlite #400BC (120v) light assembly. I have pulled the light out of the housing and disassembled and cleaned it. I plan on replacing the gasket, but I have a couple of questions. The lamp looks just like any outdoor floodlamp, but I see online that the vendors are asking $30 to $40 for replacement lamps. Is the proper lamp something special? Also I'm have a hard time believing that assembly won't leak water into it over time. Is there some caulk or something that I should be using on the gasket?
    Sacramento, CA, USA.
    Default Re: Pool light repair questions.
    Outdoor flood lamps are usually in the 65 - 75 watt range. Pool bulbs are 300 - 500 watt bulbs, usually heavy duty type (rated for more than 120 volts). They are also a specialty item and that usually means a higher price. I've seen pools with standard flood lamps in them, very poorly lit.
    The gasket is all you need, just put a LIGHT coat of pool lubricant on it (just make it shiny) and tighten the clamp. With a new gasket it shouldn't leak.
    Hey, if I install one of those yellow porch light bulbs in my pool light will it keep the bugs out of my pool?
    Jul 2006
    SE Georgia
    Quote Originally Posted by imfignewton View Post
    Oh how I wish that were true! Last year it was invasion of the flying ants,
    this year, it's invasion of the beetles!
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
