Closed Thread
Results 1 to 9 of 9
Thread: Concrete coping vs. rim lock coping
    Jul 2006
    Default Concrete coping vs. rim lock coping
    I am in the process of negotiating a contract to have an inground pool built. We saw the concrete coping around the pool and really liked it vs the metal coping. Has anyone had any experience with the concrete coping chipping with age from exposure to water and chemicals?
    Sanford, FL
    Default Re: Concrete coping vs. rim lock coping
    No personal experience - but what I have heard is that it is fine even in a salt-water pool.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    induce is offline ** No working email address ** induce 0
    We loved our concrete coping. It was really perfect. Ask your builder if he does this alot and if he is good at it. Although that may seem like a silly question to ask a builder, the concrete coping is difficult to do. They use a styfoam form that the concrete flows into and makes the ledge. The builder cannot "see" into the form, so if it is not totally full and even, then your coping is uneven or worse. I think that is why most builders are using pavers as a alt to rim lock coping.
    Jul 2006
    Thanks for the replies. I will ask about the pavers.
    GutierrezPlastering Guest
    Concrete copying is an excellent way to shape your pool, i would think because it is more uniform with the deck, and overall shape of your pool. I work with the styrafoam, and it has worked amazingly. It all depends on who the company is that will be doing it, and how much time they wait before taking it off once it stiffens, tamping it in the front and using a piece of the actual form to seal and fix inperfections. By the way Sean, may i ask who is builind your pool? Because i see your from NJ too?
    Jul 2006
    Poolside pools and spas route 9 toms river.
    Jul 2006
    I looked at your website, very nice work.
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Our pool builder will not pour concrete copings because he has seen so many pools with it chipped and replaced. I think the problem is the same as the stone coping, it has to be sealed every year to prevent chipping in freezing weather. We didn't push it anymore, but I would have like the option of concrete coping.
    Jul 2006
    I am starting to think pavers may be a better option, but cost will be a factor. The pool is 16*36 oasis similar to a kidney shaped. They are charging us $650 for the concrete coping, I am sure it will cost a lot more for pavers.
Closed Thread
