Pumps don't work - Jandy RS6
My neighbor has a RS6 and a day ago the pumps quit working. After tinkering with it, now the lights don't work either. We've swapped out the control board and took the ASCI out of the board and put it into the new board. The problem now is it still doesn't work. The controller does the power on self test and appears normal but nothing happens.
Do the ASICs go out very often? Is there something else to check?
