Thread: Clorine test dark amber in color
    Dec 2005
    South Windsor, Connecticut, US.
    Cool Clorine test dark amber in color
    I have been testing my pool water for three years and this is the first time the clorine test shows a dark amber color. Can someone tell me what that means?
    Default Re: Clorine test dark amber in color
    Usually means that the chlorine is very, very, very high. Did you just shock it?
    Dec 2005
    Last weekend. I shut down the autofeeder also. The PH has been dropping quick too. I increased it and the next day it was low again. There is not a heavy clorine smell.
    It would probably be a good idea if you gave us a compete set of current water testing results from a drops based test kit. Also tell us what type and volume your pool is and exactly what all you have added to your pool. Then somebody here can better advise you.
  1. problem with Lamotte color-Q 7 pro test
    By Amir in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2007, 02:17 PM
  2. Question on how to match color on drop test kit
    By CelticDaddio in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2007, 07:42 PM
  3. strange test color
    By roxy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-17-2006, 01:56 PM
  4. A test kit for the color blind?
    By famdog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2006, 12:38 PM
