Results 1 to 10 of 15
Thread: Decision on Zeobrite or Sand replacement
    Default Update 4/24: Decision on Zeobrite or Sand replacement
    UPDATE: Replaced 250lbs of sand saturday, April 22. Today, water is 85-90% clear and clearing nicely. Added 2x40lbs bags of salt, SWG is running at 3000ppm salt level and generating nicely. The surface of the vinyl is very rough, must be algae that scaled on there. It won't come off with a stiff poly brush, but will come off with some gentle wipes with a 'green' pad. Anyone ever run into this? Guess everyone will get a green pad to wear on their feet for a week's worth of swimming!
    Thanks for the tips, tricks and 'listening'.
    Later
    Tom
    duraleigh Guest
    Default Re: Update 4/24: Decision on Zeobrite or Sand replacement
    Hi, Tom,
    Thanks for the follow-up. That's a very interesting comment about your vinyl liner.
    I'm not positive, but I don't think that's algae. When I review your first post, I see this:
    but the problem is just like some other posters, the fine algae is going through the sand filter.
    That leaves a milky-white pool which I've been vaccuming every day and haven't seen the bottom of for 2 weeks
    Combining those two observations makes me think that something precipitated out of your water and has scaled on the vinyl.....perhaps calcium.
    To my knowledge, algae dead or alive doesn't create a scaling condition. Nor does dead algae turn a pool milky white (to my knowledge)...more like cloudy grayish blue.
    Well, if your water looks nice, that may be enough. I believe I would look at my test numbers very carefully....I think there was something else going on. Have you done a complete test this Spring?
    Default Re: Decision on Zeobrite or Sand replacement
    Dave,
    I think there may be some calc precipitated out.
    I tested about 3 days after I went back to regular chorination (during/after sand change my FC was +15) and we went clear.
    According to my handy-dandy ps233 -
    FC=3.5 CC=0 TC=4 pH=7.8 Alk=190 Cal=240 Cya=0 (week ago)
    I retested 2 days ago FC=4 CC=0 TC=4.5 ph=8 Alk=210 Cal=270 Cya=20
    The calc is coming off with a green pad but the 'gentle wipes' in some spots translate to "you gotta scrub".
    Since I run a SWG my ph is always high, and were in central TX, nothing but the best mineral water in the west. Filtered by the limestone rocks and pumped out of the aquifer, clogging shower heads and coffee pots in a city near you!
    Anyway, I'm not looking for quick fix, I know this will take work, But if you know of anything that could help soften up some of that calc to make it easier when scrubbing every inch by hand please pass it on.
    Oh, and since were very far (weatherman says ~20") behind in rainfall for 12 months running, every week I just add more of that mineral water back to the pool for top-off, durn.
    Thx all,
    Tom
    duraleigh Guest
    Hi, Tom,
    I wish I could offer some practical advice for getting whatever it is off the wall.....I just have no experience. Home Depot sells "sulfamic acid" a very mild acid for cleaning masonry.......I just don't know if it would have an effect on your liner if you brushed a little on. Smarter folks than me may have an opinion.
    Yeah, your pH and Alk numbers are up there pretty high.....very conducive to scale formation. Adding some muriatic acid would help a lot
    I believe I would work on reducing pH to around 7.2 - 7.6 and Alk down to the 90 -120 range........that would probably prevent you from ever geting back into that scaling condition.
    I have asked several pool stores about adding DE to the sand but they never heard of it. Though they have heard that their $23 Sand Filter Cleaner works well ;-)
    Sounds like your water is looking pretty good....nice work. I do believe you need to add some muriatic, however.
