Results 1 to 10 of 10
Thread: What Not To Do To Your DE Filter
    Katy, Texas, USA
    Default What Not To Do To Your DE Filter
    OK so with the pool 1.5 years old and still problem of fines in pool I final found 2 hours to do my first ever annual tear down cleaning of our Pentair FNS 60+ DE filter.
    Holy crud Batman ! OK so not a pretty picture. Most DE etc at top of unit, between fins at top is completely plugged and when look down the middle you see a core of DE that is still left after removing all the caked up fins.
    This pool boy has been good at maintenance, backwashing several times until clean returns when pressure builds up and then adding ~6 lb of new DE via skimmers.
    Where did I go wrong or is this what it's supposed to look like ?
    Snaps attached:
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Default Re: What Not To Do To Your DE Filter
    I have the exact same filter. We usually open our pool on Memorial Day and close mid-October. The pool company does the closing which involves tearing down the filter and cleaning the grids. I don't believe I've ever seen the filter that dirty. Then again, we are only using the pool for 5 months and then closing....Sorry not much help
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
    Katy, Texas, USA
    Thanks MaryLee
    Lucky you have your own Poolboy ! Here I have to do it, plus we run our pool year round with no cover. So at least I know this is not normal .
    Quote Originally Posted by Katy-Texas
    Actually, it might perfectly well be normal for a pool that is open year round. Hopefully someone else can chime in
    18 X 40 IG Vinyl
    Pentair DE Filter
    There is actually a technical term for the caking of DE that your pictures show. It is called 'bridging".
    I have said many times before in the forum that backwashing a DE filter is NOT a good idea and that they really should be torn down when they needs to be cleaned. Not a popular opinion in the forum, btw! Your pictures illustrate my point perfectly! The problem with backwashing is you never really know how much DE is washed out and so you never really know how much to put back in. If you put in too little you run the risk of clogging the grids with dirt and organics. If you put in too much you can cause bridging between the grids and the DE can cake into a cement like mess....sort of like in your pictures! The errors can compound with each backwash.
    It really does't take THAT much time to break it down and clean it properly if it is done on a regular basis! Save backwashing for time that you are killing an algae bloom and are trying to get suff out of the pool and when you are done break it down, clean it, and recharge it with the proper amount of DE!
    Just my 2 cents (for the umteenth time it seems! Maybe someone will take note of what I have been trying to say!)
    holy crap..no insult intended, but methinks i'm very happy i have a sand filter
    Katy, Texas, USA
    Thanks all. Yep, agree with Waterbear! I now resolve to tear down and clean every 3 months !
    Another question, the cloth on the fins was rough, almost crunchy, felt a little like rough grit sand paper when sliding the fins down beside each other. Manual said that may get "Liming" on fins where get some scale buildup (initially filled pool with hard tap water, just this week gettig a water softener installed). So I think that is the problem. Manual said if "Liming" to bath fins in mild HCl soln. They are tall so I was thinking of doing this next tear down in a clean tall plastic garbage can.
    Agree?
