Closed Thread
Thread: Exposed Aggregate Decking Over a Septic System
    Jul 2006
    Default Exposed Aggregate Decking Over a Septic System
    I'm new to this board and have a question that I can't seem to find anything on after a few quick searches, so sorry if it's a redundant subject.
    We're putting in a pool and large deck area. The exposed aggregate concrete patio deck will go over part of the septic tank and the access cover. Obviously we will install a sleave to gain access, but I'm concerned about a cover. I don't want to install this beautiful deck and have a big ugly cover. Has anyone run into this? Any solutions?
    Is there a way to make an exposed aggregate cover to match the rest of the deck? I will go back to our "deck guy" next week to discuss this, but I'm wondering if there were others that did something similar so I can reference the ideas in my conversations with him.
    Thanks!
    dplte
    Jul 2006
    Default Re: Exposed Aggregate Decking Over a Septic System
    Just keep in mind a septic system will not last forever. In my area they last 15-20 years. If you have a problem with your system you may have to remove decking to replace a tank or leech field repairs. I haven't heard of a deck being put over a septic tank. Is your pool close to the septic system? I would try to find an alternate location for the deck.
    Jul 2006
    It's really just a large deck area. Instead of doing a separate deck area out of composite decking or patio blocks, we thought it would look far nicer keeping it in the same decking material.
    I hear what you're saying, and it's a good point and something we need to make sure we realize going in...Thanks!
    Central Texas
    You probably shouldn't deck over the septic field, but decking over the tank itself shouldn't be a problem. Work out a joint pattern in the deck so that a small portion over the tank lid can be lifted out. That portion of the deck should be specially constructed with extra reinforcing and lift spots embedded. Our septic tank lid has a hole in it, so some sort of venting may be standard practice, but I don't know that for certain.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Mandeville, LA, USA.
    This product is probably too small for your application but it should give your concrete guy the idea: Pour-A-Lid.
    Jul 2006
    Outstanding, thanks for the info!
Closed Thread
  1. How best to forestall rust on exposed screw heads?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-24-2012, 01:15 PM
  2. septic tabs?
    By lguti69 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2012, 07:59 PM
  3. septic tabs
    By vinper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2011, 07:17 PM
  4. Pricing for exposed aggregate decking
    By poolpup in forum In-Ground Pool Construction and Repair
    Last Post: 08-28-2006, 09:24 AM
  5. Exposed Aggregate & SWG
    By Simmons99 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 01:53 AM
