A number of questions
I recently started on the BBB thanks to this forum and my pool has responded fairly well to it. It was in sorry condition before hand.
Question #1: My combined chlorine is still high. I assume that there is still a number of things that the chlorine is killing. But how does it get lowered? After it is done killing the miscellaneous items, will it evaporate like the free chlorine??
Question #2: There looks to be a lot of dirt and stuff like that on the floor of the pool after I sweep. Is this the dead algae?? I noticed that when sweeping the pool, the lines returning from my pump and filter shoot out this cloudy stuff that appears to be the dirt. Almost like the filter isn't able to filter it all. It gets some but what ever it can't get it gets returned to the pool water and clouds it up.
Question #3: Is there an advantage to running the pool over night instead of during the day?? I figure since the sun is not out evaporating the chlorine at night, it would be much better.
Thank you all for you time.
