Thank you, Waste! (interesting name
I should have mentioned, but we are using Baquacil. I know Baquacil can be foamy, but we've never had a foam problem with it and we've been using it for 3 years. The water has been tested, twice, and everything is within range.
The water level is definitely high enough. The weir of the skimmer does open enough to let water in and seems to be working okay. Just wondering if perhaps it should be laying completely down or open enough just to let water in.
I'm still thinking the gasket on the strainer basket doesn't look great, and wouldn't that be the easiest thing to replace? I tried Hayward's website but couldn't find instructions for changing the gasket. How do we remove the old one, and install the new one please? Is it very difficult for someone who's never done it before?
Thanks again, your help is greatly appreciated!!
, which may have been the cause for any air in the pump. As for a chip off the corner, as long as it doesn't extend to the 'rib' on the cover you should still be able to fully seal the lid, unless it's a front corner and prevents the locking knobs from creating a full seat. I can't blame you for wanting to use up the Baq you had, that stuff isn't cheep, but do give a read like I said above. If you want to switch to a chlorine pool next year, I think the vast majority of people here would tell you that you are making a GREAT choice. As for salt water systems, I really like them and so do quite a few folks here. What you'll need to do (anytime between now and next spring) is to look into the SWG (SWCG) section of this forum, and see if it will be the right thing for your budget and pool (there should be a few 'cost analysis' of whether the unit actually saves money vs a bleach pool (it has a fairly high 'up-front' cost, some chems are still required to maintain the pool, cells need to be replaced periodicly and it costs electricity to run one) - but even so, the yearly cost will probably be less than a well maintained Baq pool. I've babbled enough for one post - if I can be of any further help, never hesitate to ask!
We did call the man that rebuilt our pool so I'm hoping he can get out in the next couple of days. Right now I have only the valve open that feeds from the bottom. Is it okay to run the pump like that for a while, with just the one valve open?
