Re: Removing winter cover
Just make sure you get as much water off the cover as possible. You don't want that water getting back in your pool if possible. If you don't have a pump you can use a garden hose. Just toss one end on the cover and leave one end out in the yard. Take the end that is lying in your yard and suck the air out of it until the water begins to flow. Its a slow process but it does work.
After that get at least two (more is better) people to help you slowly remove the cover off the pool and on to the grass or driveway. Once its off get an old mop and bucket and try to clean it as best as you can. Let it dry and then sprinkle some corn starch or baby powder on it and fold neatly.
