We finally finished making the conversion to your BBB method and have now been using Clorox Ultra 6% for 2 weeks.
Today while swimming we noticed a yellow/brown stain from the water line down on the steps and the skimmer boxes, also the skimmer baskets are no longer white. This stain was not there before we changed to bleach!!![]()
Before finding this forum, we have always used Cal Hypo and pucks. We have always used our well water to top off due to evaporation or replace splash-out. The CYA has been creeping up from the pucks (as expected) so we quit using those about two months ago, and have been draining and replacing 500 to 1000 gallons every day or two to try work the CYA level down. The only real change is the bleach.
Below is the latest results:
Water Temp 87
pH 7.4 by titration
FC 6.0 ppm (FAS-DPD)
TC 6.0 ppm (FAS-DPD)
CC 0 ppm (FAS-DPD)
TA 80 ppm (by titration)
CH 250 ppm (by titration)
Phosphates <100 ppm
CYA = 55
Water is crystal clear![]()
Added 120 oz Bleach this evening to bring FC back up to 8 ppm per Ben's BGC.
Finally ---- the question ---- What to do about the stain --- We really do not want to go back to Cal Hypo!!![]()
