Re: My sand filter sucks, new filter options?
Hello,
I had taken my water sample down to the pool place. They said all my levels where fine. But, I may want to increase my chlorine level and to get some CYA. So I did that yeasterday.
Before putting that all in, the green in my return has gotton worse and the pressure in my pump is now down to 5 where it was up to 9 or 10 2 days ago.
I am getting new gaskets, where the clean out is, if you turn it just a little the pressure goes up??? I think from changing the sand a couple of times already the gaskets may be bad. I am going get new gaskets, more sand, the Aquachem sand cleaner and DE?, I think it is called to increase pressure. I hope this works. I am getting fustrated. Although, my pool is still clear, Thank you Lord!!!! If I don't ask fast it won't be.
Do you have any other suggestions?
Thanks a Bunch,
Lisa
