Results 1 to 10 of 13
Thread: Operating Valves
    Sanford, FL
    Default Operating Valves
    Okay, the new pool is in, but I don't know how to run the equipment. I haven't been given any maintenance equipment, manuals, instruction, etc.
    I actually thing the builder would prefer if I didn't touch anything - at least that is the feeling I get from him.
    Here are some pics on my equipment. I have a Hayward cartridge filter with a 2 HP pump, and Jandy valves. My initial suspicion is that if you turn the valve so "OFF" is towards a certain pipe - than that connection is sealed off right? The "MD" - is that main drain. I guess the vac - is for the vacuum line. So when I want to vacuum - what position do I place the valve? Also - right now they have the spa drained (my pool is almost overflowing now) - how do I set it to spa mode - where the water is cycling through the spa and overflows?
    PS: this pic was taken about a week and a half ago - so this isn't the current setting of the valves.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Country Living in Comal Co., Tx
    Default Re: Operating Valves
    Hi Phil,
    Forgive me for hijacking your thread so early, but where did you get that GREAT "florida-room" screen cage?
    About your valve question....it's counterintuitive, but the valve HANDLE doesn't point in the direction of flow on those valves. If you have a clear basket vacuum cover on your pumps, try opening (or closing) the valves to see the effect on the supply-side water in the pump window. That will demonstrate the "open" position of the valves for you. (open=90 degrees or perpendicular to the waterpipe direction)
    I'm sure someone will explain it better, but I had to write my best in order to avoid the appearance of hijacking
    STS
    Ontario.
    Pool companies seem to be pretty darn good about having manuals available on the net. Here's some links:
    Hayward: http://www.haywardnet.com/products/M...anuals_all.cfm
    Jandy: http://jandy.com/html/productsupport/#manuals
    The builder is not finishing the job if he leaves you like that. Most products and manuals have right on them "leave with owner:.
    Jul 2006
    Nova Scotia CANADA
    Default Re: Screen Room
    Quote Originally Posted by South_Texas_Sun
    Hi Phil,
    STS
    Umm, sorry about this, but me too....lol
    That screen room is gorgeous!
    How big? How Much $ ? ( if you don't mind sharing)
    and do you have a website for it?
    & can it be a DIY project or is it something that should be left to professionals
    ( due to degree of difficulty of install)
    Do you think that it could handle snow?..lol
    again, I'm sorry to butt-in & change the thread topic, but your new pool is just too wonderful to ignore & I adore your screen room
    Best of Luck to you
    ( & I'd leave the PB a vm message about bringing all manuals to you)
    Sanford, FL
    We have to here in florida - it is 27' X40' with a 8' covered area with gutters - about $13K. It's the only way we don't get carried off by the bugs (and it helps to keep out the snakes). There are very few pools in FL that don't have the screen enclosure.
    It can be DIY - I have a friend at the office that added onto his - check local building wind code (I see your in TX) - we have to install cement footers and lots of ty-downs. In my area it must withstand 120mph winds without ripping off the house. They did major damage to neighboring houses during the hurricanes in 2004.
    The frame is aluminum and has slots in it to secure the screen - similar to the screen frames on windows. Then they just bolt them together.
    Here is a company I found that has a location in TX. http://www.screenenclosures.com/
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    Sanford, FL
    On the valves - I have pool school at the end of the week - DH just called and said that they were out and the spa has water now. I guess I will read those manuals and then see what they tell me on Friday.
    Another stupid question - what is supply-side? I have also read "suction side" - is there a place I can get definitions for these terms. I totally understand all the chemical stuff - but the plumbing seems like a totally different world to me
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    supply side is the side that the water comes out of (going back to your pool) suction side is where the water flows into (gets sucked into) the pump.
    Ontario.
    Bet you bite your tongue hard when the pool school starts laying out the 4in1 tabs/floc/algaceide/phosp/bromaine/bacq, etc., etc., etc.
    here's a guide to every bit of lingo you'll ever need to know. also has an alphabetical search function.
    http://www.poolcenter.com/pnlingo.htm
    Sanford, FL
    Quote Originally Posted by Spensar
    Actually I am going to tell them if they add anything to my pool I will have to kill them
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
