Finding a leak?
I am losing 11/2” a day of water. I have checked the equipment and all is dry. The loss is the same with the pump on or off. I let it drop below the skimmer and return and it still kept going. I put on some goggles and inspected under the ladder, the cove and all of the gopher craters. I then looked at the walls and the rest of the bottom and nothing stands out. I’m going to buy some beets and make a dye. I could really use some suggestions on what to do next.
Thanks again
Jennifer
