First, do a walkaround, if you have ground cover like gravel or mulch, move it aside a bit - keep looking until you find wet or soft ground against the pool edge, this will help pinpoint the location to some degree, saving you from searching the entire pool from within.
If there is NO soft wet ground near the edge of the pool, the leak may well be more central, but it will again help you locate the leak by at least eliminating the walls and cove area of the pool.
