Results 1 to 10 of 14
Thread: STeps any suggestions?
    Lehigh Valley, PA
    Default Re: STeps any suggestions?
    We had the same problem with algae growth until we drilled 2 inch holes into the sides, two on each side, and one in the front of the bottom step. That was about 6 weeks ago and we haven't had any algae since then.
    Our steps aren't fastened to the deck at all. The front stays down from the weight of the three PVC tubes and the back stabilizes them with the weight of the hanging tubes. They don't float anymore, now. We installed the flanges for the handrails but did not drill out the deck. The rails sit in their 2 inch deep holes in the flanges and in the holes of the steps.
    I lift the hand rails out in the evening when I put on the solar cover. Oh, we cut that monstrosity, I should post about it. Moving the steps for cleaning is a simple matter of unhooking the hanging tubes from their S-hooks; this now floats the steps a tiny bit, just enough for me to reach the rope and haul out the bottom tubes. Once they're out, the steps just sort of come to the surface for removal.
    We're really pretty proud of our weight tubes.
    Carterville,IL
    I have wedding cake steps in our new pool. We have a concrete block and three red bricks in the front. We tied a heavy duty nylon string to stabilizer jug w/ rocks in it to hold the back down (till it is fastened to the deck that isn't there yet). It sits on a pad and moves slightly. The question I have for you all, is this: Is there going to be futuristic problems w/ the water chemistry from having the block and the red bricks in there? The red bricks are in heavy duty freezer bags?
    Also, I am now worried about the algae problem you all are having and I haven't yet. The pool has only been up and running for a month now.
    Any suggestions?
    Carterville,IL
    Just took another look at my steps. The first three steps from the bottom actually have 5-6 cut out slits on each side of the steps. This should be relatively similar to thou who stated they "cut" holes into each side of the steps????? This should allow for water circulation through and I also realized that the steps aren't flush against the pool wall in the back. Their is about a 5-6 inch space which should also allow for water circulation. I am trying to convince myself that this is good and I won't have any future algae problems. Cross thou fingers and say a lil prayer for me.
    I used plastic bar-bell weight set from a yard sell. Just zip-tied them together and to the shelf under the steps.
    I've got about 120lbs. on my steps.
    Lehigh Valley, PA
    TraceyB,
    The algae will come, just give them time
    Our steps also have the cut out slits on the sides and they, too, sit a few inches away from the pool wall. I had never actually thought about algae growing under the steps until the day came when I noticed a narrow green band peeking out from around the bottom step. I scrubbed it, got rid of it, and some days later it was back. So I moved the steps.
    YIKES!!! A slimy green area in precicesly the complete footprint of the steps. What a mess!!!
    There's enough circulation behind the steps, due to their distance from the pool wall, to keep (visible) algae from growing but the slits alone are not enough to adequately move water under and through them. Now that we've cut the holes in the sides and bottom front this issue has been resolved. When I brush the pool I pay particular attention to swishing some water in direction of the holes. I also put the hose nozzle behind and under the steps when I add water.
    I suspect there will be some algae growth directly under the bottom step where it sits flush on the pool bottom because it's weighed down and no water to speak of can circulate there, but that's a vast improvement over the several square feet of green gunk we had previously.
