Thread: Leaving town for 2 weeks
    La Jolla, CA
    Default Leaving town for 2 weeks
    I am going to be leaving town for 2 weeks with no one to attend to my pool.
    I have a small volume endless pool (1500 gal). Covered always. I keep my Fc around 3-5ppm with a CYA of around 20-30
    I was thinking of using some form of solid chlorine for this. What dissolves slower. Trichlor pucks, CaHypo sticks. I just don't to have a FC of zero when I return
    Andy
    Default Re: Leaving town for 2 weeks
    I would shock with bleach, add a tri-chlor puck in a floater and dose with polyquat just to be sure. With a cover, you should be fine.
    Dave
    Trichlor will dissolve much slower than cal-hypo, just keep in mind that it will also pull your pH down. I agree with David...shock it, put trichlor in a floater (make sure your pH is high enough to compensate and that you don't let it float to the edge of the pool) and cover it. The worst thing that will happen is that you'll have to shock it again when you get back...
  1. Leaving equipment outside all winter?
    By denanbob in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-12-2007, 07:58 PM
  2. Leaving for a long weekend
    By MaxxFusion in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-10-2007, 09:33 PM
  3. Leaving filter and pump outside?
    By sharklinejk in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-13-2006, 12:55 PM
  4. Going out of town
    By diwilson in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-04-2006, 08:41 AM
  5. going out of town
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2006, 01:07 PM
