Closed Thread
Results 1 to 10 of 14
Thread: Hose popping off
    Default Re: Hose popping off
    I've never seen a hose "expand" before, on my pool, they just look like they "stiffen up" some with a bit of movement, but then they equalize and settle and look the same as always. I'm not familiar with the Chlorine pack you're describing since I only use bleach, so I really can't say whether that is part of the problem or not.
    I wouldn't trust it not to pop off again, not something you want happening when you're not around, I would look into it a bit further because it just doesn't sound right.
    Can you run without a chlorine pack and see if the problem goes away?
    A chlorinator should not give that kind of backpressure to expand a hose.
    Massachusetts
    matt:
    Actually, I did by-pass the chlorine system and go directly to the return. The hose seemed to be fine. I think I was being a bit overly concerned with the movement of the hose. It's just a bit more flexible than the original hose. I will look into the hose and clamps recommended earlier. In the meantime, I'm only running the pool when I'm around to keep an eye on it.
    I truly appreciate everyone's responses.
    i think that makes sense with own experience matt. i note that the tiger flex hose where i use it doesn't expand, but it does go sort of rigid when pressure is applied.
    Exclamation Re: Hose popping off
    If you go the 'tiger-flex' way, DON'T USE CLAMPS !!!!!!!!!!, use schedual 40 fittings and PVC primer and glue to secure them (threaded reducers with a 1 1/2" slip fitting are available at any decent hardware store). Tape whichever threaded reducers with 3 wraps (all the way up the threads) and glue the 'bell' end to the pipe. Make sure you read the instructions on the can of glue to insure a good seal. I've taken a number of 'shortcuts' in my explanation, but following this will insure a good connection. (if you've any questions about what I've advised, ask and I'll go into further detail). I beg for you to trust me on this, as I spend a lot of time every year correcting leaks caused by homeowners using tigerflex and clamps. (it's only a small % of fixes I have to do as opposed to those due to installers using 'black poly' - but that's something for the 'China Shop'. )
    T-cal, welcome to the forum, I want you to have a great 'pool experience' so am trying to prevent your doing something that will be a continual headache. Do it once, do it right and enjoy the pool.
    Carterville,IL
    Quote Originally Posted by waste
    Is there any way you could attach a photo of the correct fittings? I have silver clamps around all of my hoses that tighten w/ a screw and I DO NOT want to wake up one morning and have to refill the pool. I would love to see how your hoses are attached. Also, where would one find "tiger flex" hoses or GOOD quality hoses. I'm all about a little extra $ for a better lasting "anything".
    Quote Originally Posted by traceyb
    Tracey, I don't want to cause you any loss of sleep, the clamps work for a few (or many) years, I was only trying to say that 'if you have to make a change, and were using PVC 'flex pipe' ', glue, don't screw (as in the clamps).
    Don't be afraid of the connections you have! I only suggest that, if needed, you make the change to PVC glued connections (which are a chemical and mechanical bond) vs. a purely mechanical (the clamps) connection. It's an old saying but "if it ain't broke, DON'T FIX IT (until necessary) .
    I certainly welcome you to this forum! and hope you have nothing but trouble-free swimming! However, should you ever have any trouble, know that I and the rest of the members will 'bend over backwards' to help you!
    Fear not Brave Soul! - Waste
    Well, judging from all teh pools around our town (and I believe we have close to a 100% pool vs house ratio), tigerflex with barbed connectors and clamps seems to be the most common installation proceedure, some have the lower cost hoses, more like your standard vacuum hose.
    I replaced my clamps right away with a stronger clamp - looks the same, but a way higher quality that won't slip when tightening.
    Standard hose clamps are really a waste of time and energy and can get people frustrated relatively quick, I chose to forego that aggravation by throwing the pool company supplied crap into the "spare repair parts bin".
    Haven't had so much as a drip yet.
Closed Thread
