Thread: New water and off to a good start, BUT
    scootchu is offline Registered+ Thread Analyst scootchu 0
    Default New water and off to a good start, BUT
    Nevermind I am a dope and made a mistake adding Baking Soda to a pool filled with water with a high TA to begin with. I bow my head in shame. If my TA is sky high , but my pH is 7.2 should I worry much and try to bring the TA down or just wait and keep and eye on the pH? 17,000 gallon AG 27' pool.
    Sanford, FL
    Default Re: New water and off to a good start, BUT
    Add some acid to lower your PH to about 7.0 - this will also lower your TA. Aerate the pool by turning the returns so that they ripple the water, turn on a fountain, or have a bunch of kids play. This will raise the PH while maintaining the same TA level. You may have to do this a couple of times.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    duraleigh Guest
    How high is "sky high"?
    Quote Originally Posted by duraleigh
    Ummmmmmmm either my ALK 2 reagent is bad or it is off the charts because I cannot get the green to turn red. I have a fountain and a slide that are running. pH is at 7.4 now.
    use a little more acid and get the pH back down to 7.0, keep aerating. It'll get there!
