Thread: stabilizer granules on bottom of pool
    Southern Ontario
    Default stabilizer granules on bottom of pool
    ...whoops, somebody added stabilizer granules through skimmer...must of used the whole container...now there are white granules on bottom of pool...what should I do?????
    Northern Kentucky
    Default Re: stabilizer granules on bottom of pool
    You can vacuum them up into the filter and don't backwash for a week.
    However, if they were put in the skimmer, they should have gotten caught in the filter in the first place...
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Grace is right, if it was put in the skimmer, they should have gotten trapped in the filter. Makes me wonder if your pump is too strong and your filter not big enough. Sometimes when that is the case, stuff just gets blown through your filter too fast instead of being filtered properly.
    Southern Ontario
    I vacuumed up the granules...and won't backwash for a week......I found out that the granules were "sprinkled" over water to start with..before realizing they had to go through skimmer.......yep, should just do it myself!!
    Don't beat yourself up over it. I have seen some CYA containers that said to broadcast the granules over the surface of the pool. Bad idea. You don't want cyanuric acid laying on the bottom of your pool - especially if it is a vinyl liner.
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. Will CYA granules on bottom of vinyl pool cause problem?
    By zephans in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-13-2008, 08:11 PM
  3. Help!Cloudy AG after Borax/chlorine granules
    By pam100257 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-12-2007, 08:43 AM
  4. Undissolved CYA Granules
    By fhcaputo in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2007, 09:03 AM
  5. Tablets or Granules?
    By bob57 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-31-2006, 09:44 AM
