Thread: FAS-DPD Chlorine Test Question
    Sanford, FL
    Default FAS-DPD Chlorine Test Question
    When you put the powder into the water - should it turn pink? If it doesn't - does it mean there is no chlorine (combined or otherwise) in the water?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Mandeville, LA, USA.
    Default Re: FAS-DPD Chlorine Test Question
    Correct, no chlorine.
