Results 1 to 10 of 13
Thread: Still green (ish)
    Sanford, FL
    Default Re: Still green (ish)
    If it's not metals - then you are not getting the chlorine up to a level where it will kill the algae. You need to get it to 20ppm - test 3X a day and every time raise it to 20ppm - the more you are able to keep the chlorine level high and steady - the shorter amount of time it will take to kill the algae.
    I would still recommend that you have your water tested again for copper. When you shock your pool it will cause the metals to come out and stain your pool - which would not be good.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Orland Park, Il (near Chicago)
    We just had the metals tested and they're fine. I have been consistent with keeping at shock level (since converting to BBB last week), but I'm getting discouraged because i'm not seeing any improvement.
    Sanford, FL
    Then take it to 25ppm and keep it there. When you are testing through-out the day - where are your chlorine levels?
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    Today my FC is 20 and has been consistently at least that high for the last week. I even had it up to the 25+ level for a few days.
    Sanford, FL
    When you are testing throughout the day - is your chlorine dropping a lot? If so the algae can be re-growing while the chlorine level is lower than 20ppm.
    I know that it can be frustrating - there was a person who had algae for about 3 weeks until she finally kept her chlorine levels consistently above 20ppm for a few days- then the pool finally cleared.
    What's the saying around here - the answer is simple, but implementing the answer takes persistence and patients?
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    Sanford, FL
    Still have to kill the algae first. If your pool is green the algae isn't dead yet. Once your pool is a cloudy blue - then your filter will need to filter out the dead algae. Most people's filters can do this without the added expense of "floc" or a clarifier.
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    Sanford, FL
    Quote Originally Posted by RjBeals
    If you want a crystal clear pool again, Shock & Flock it. This forum probably will not condone it, but its a sure way to get clear water in about 1-2 days.
    It's not that it is not "condoned" - its that it is usually an unnecessary expense and usually is a temporary fix. The forum is about managing your pool with only the necessary chemicals, not adding anything you don't need, understanding your chemicals in your pool, and having a great pool without hundreds of $$ in crap from the pool store that leaves you worse off then before.
    Completed 8/21/06
    Spa with spillway
    SWCG - Aqua Rite
    mbar's Avatar
    Ashland, PA
    I agree with Simmon99 - you neet to take your chlorine higher, you may not be getting to breakpoint yet - so I would take it to 25ppms and be very consistant - everytime it goes below 25 hit it again with more chorine to get it back. This way it will kill all of the algae, you need to have all the algae dead before you use floc - then if the dead algae isn't clearing fast enough you can use floc, let it stand overnight then vacuum to waste. Be sure to brush the sides and backwash the filter while you are killing the algae, leaving the filter running 24/7.
    Northeast PA
