Results 1 to 10 of 13
Thread: Still green (ish)
    Sanford, FL
    Default Re: Still green (ish)
    Quote Originally Posted by RjBeals
    If you want a crystal clear pool again, Shock & Flock it. This forum probably will not condone it, but its a sure way to get clear water in about 1-2 days.
    It's not that it is not "condoned" - its that it is usually an unnecessary expense and usually is a temporary fix. The forum is about managing your pool with only the necessary chemicals, not adding anything you don't need, understanding your chemicals in your pool, and having a great pool without hundreds of $$ in crap from the pool store that leaves you worse off then before.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    mbar's Avatar
    Ashland, PA
    I agree with Simmon99 - you neet to take your chlorine higher, you may not be getting to breakpoint yet - so I would take it to 25ppms and be very consistant - everytime it goes below 25 hit it again with more chorine to get it back. This way it will kill all of the algae, you need to have all the algae dead before you use floc - then if the dead algae isn't clearing fast enough you can use floc, let it stand overnight then vacuum to waste. Be sure to brush the sides and backwash the filter while you are killing the algae, leaving the filter running 24/7.
    Northeast PA
