Results 1 to 10 of 10
Thread: Constant PH climb suddenly stopped
    Default Re: Constant PH climb suddenly stopped
    Quote Originally Posted by geordie
    Solar cover was clean and had not been used so far this year at all until 10 days ago.
    TA 180 - right where it has been all year... and in the same neighborhood for about 5 years
    The data I quoted above is the answer to this "mystery". A TA of 180 is quite high and will lead to a lot of carbon dioxide outgassing and this causes the pH to rise. However, when you add acid to restore the pH, you should have seen the TA reduce as well as the pH, though it doesn't get reduced by very much. Perhaps your fill water is high in TA so whenever you fill up after evaporation you put back in more TA (that's the most likely scenario).
    Now when you put a cover on your pool, you essentially stop the carbon dioxide outgassing and therefore stop the rise in pH as well as your need to add acid.
    Fortunately, this is a case that is perfectly explained. If you want to reduce your need to add acid, you can either use the cover as you are now doing or you can lower your TA significantly using Ben's Procedure for Lowering Alkalinity though you may need to also apply this procedure to your fill water before adding it to the pool (if possible) or else your TA will rise again.
    You should probably test your fill water to see what the TA level is. If it's high, then that would explain why it never seems to drop in spite of the apparent carbon dioxide outgassing.
    Richard
    geordie is offline ** No working email address ** geordie 0
    Thanks Richard, makes perfect sense. Yes, the fill water has high TA. Our "city" water is well water and has high TA and high ph. Since you explained the outgassing problem I completely understand it. (not really a problem... just a new twist).
    I really gave up a long time ago on trying to lower the alkalinity in the pool. To lower the ph and keep it low enough long enough for aeration to work, is way too much trouble given that it all immediately begins to rise again from the fill water. Rain water doesn't appear to be much better as an additive.
    Thanks for the help.
    duraleigh Guest
    Richard,
    That was a very insightful post.....I learned from it and I imagine others did as well....Thanks!
    Poughquag, New York, USA.
    Ha! That explains why my PH was low after leaving the solar cover on for 4 or 5 days last weekend when we were out of town. I have an SWG and my PH stays rock steady at 7.6, except this weekend, when it was somewhere between 7.2 and 7.4 (I have trouble seeing the colors that well).
    Quote Originally Posted by tphaggerty
    Well, now you've introduced another mystery. Something introduced into your pool is apparently acidic so that when you have the cover off with carbon dioxide outgassing this compensates so you have no net gain in pH. But that still leaves the question of what is driving your pH DOWN when the cover is on. I have no answer for that one! Anything unusual about your pool that could explain this?
    Richard
    Well, here in NY the rain is pretty acidic. We had about 1" (or possibly more) of rain during that same period (which on a 20x40 pool is about 500gals). Does that work?
    (Plus we had one small, very icky decomposing frog, but I think he was on the cover and didn't drop in until we took off the cover).
    Yup, that could do it if the rain were particularly acidic. You would have needed the rough equivalent of 4 cups of Muriatic Acid to go from 7.6 to 7.3 in a 24,000 gallon pool (my rough estimate from your 500 gallon, 1" number, assuming average depth of 4 feet and assuming a TA of 100). 4 cups of Muriatic Acid in 500 gallons of pure water would make the pH of about 4.
    Richard
