Okay, the new pool is in, but I don't know how to run the equipment. I haven't been given any maintenance equipment, manuals, instruction, etc.
I actually thing the builder would prefer if I didn't touch anything - at least that is the feeling I get from him.
Here are some pics on my equipment. I have a Hayward cartridge filter with a 2 HP pump, and Jandy valves. My initial suspicion is that if you turn the valve so "OFF" is towards a certain pipe - than that connection is sealed off right? The "MD" - is that main drain. I guess the vac - is for the vacuum line. So when I want to vacuum - what position do I place the valve? Also - right now they have the spa drained (my pool is almost overflowing now) - how do I set it to spa mode - where the water is cycling through the spa and overflows?
PS: this pic was taken about a week and a half ago - so this isn't the current setting of the valves.
