Re: Losing Water!
I don't think you'll be looking for standing water, however, spongy ground is something you may be able to detect.
If you have ground cover or gravel around the perimeter, move it aside every couple of feet and poke your finger at the ground.
Another method is from inside the pool, walk around inside and poke your toe down every foot or two, the liner should have some give where the earth is saturated beneath it and the rest of it should be relatively hard in comparison.
This should narrow it down significantly for you.
