Results 1 to 10 of 41
Thread: Where to start?
    Northern Kentucky
    Default Re: Where to start?
    yes, you may use 2 or 3 parts distilled to one part pool, and multiply your result by 3 or 4, accordingly. You lose some accuracy, but it will get you closer than "well, it looks dark brown"!
    This is affectionatly known on this forum as "CarlD's shot glass method"
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Orland Park, Il (near Chicago)
    Just curious if you can accomplish the shot gun method by reducing the number of test drops required i.e. for FC my test kit tells me to add 5 drops. What if I only add 1 or 2 drops and multiply accordingly? If this method works it eliminates a step (adding distilled water) and saves on testing liquids.
    Steve #1 is offline ** No working email address ** Steve #1 0
    Well, knarf, sounded like a good enough idea to me so I gave it a shot to see what happened. Used 1 drop instead of 5 and it was darker than 5 which would put me at 25 so I'm probably at about 30....... or this method doesn't work.
    keithw is offline Registered+ Thread Analyst keithw 0
    Doesn't work. You have to dilute the water with distilled water. But loses accuracy. Better to get a DPD-FAS test kit that test higher than 5PPM.
    Thanks for the buzz kill keithw.
    It appears that the high CYA is the root of my problem and from what I understand, the only way to lower it is to replace the water. With the level of CYA, about how much water am I looking at replacing to get to a more manageable level? I'm guessing this would also help the Harness level?
    With this in mind, anyone know the effects of pool water on grass? We're under mandatory water rationing here and it's a $1500 fine if you water your yard any time other than your 12 hours a week you are allowed however usage for pool maintenance is allowed. I could kill two birds with one stone if it wouldn't have ill effects on my sun baked grass.
    ...... and thanks for all the help so far.
    Scottsdale, Arizona
    Where do you live? Is there a concern with the water table in your area? Given the drought conditions I'd doubt it but it's something to think about so your pool does not heave when empty. Mine sat empty for 3 months here in Az and not even a crack ... If your water is not real salty it may not be a problem on the grass. What kind of grass?
    Sounds like the water has been in the pool for a long time.. A drain and refill never hurts in that situation.
    I'm in north Texas (Dallas). The only concern with the water table is the lack of one. How do I know if the water is salty? The grass is St Augustine so it is pretty sturdy except that it is dry now.
