Results 1 to 10 of 41
Thread: Where to start?
    Northern Kentucky
    Default Re: Where to start?
    The main reason for doing several smaller drainn/refills is to avoid any potential problem with an empty pool... heaving, cracking, etc. If you drain the pool, there is only the pressure of the ground pushing in on the walls, and no longer pressure from the water pushing back on the walls
    ETA: keep it at shock levels until you have O CC, then let it drift back down to 8 or so, if you keep the high CYA
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Scottsdale, Arizona
    Lets talk him into being our "BIG PLASTIC SHEET" Guinea Pig....
    Ya know you want to try it Steve
    Steve #1 is offline ** No working email address ** Steve #1 0
    BIG PLASTIC SHEET? I'm guessing I need a big plastic sheet.... then what do I do with it?
    Scottsdale, Arizona
    You really don't want to know ... You may be crazy enough to do it.
    The theory is that if you cover your pool with a big plastic tarp and start pumping the water out from the bottom while at the same time, filling with new water on top, You can purge all the old water without risk of cracks...
    Now that's just crazy....... but jumbo trashbags filled up and tied off should work right?
    Sanford, FL
    Red face Re: Where to start?
    OMG - when I heard the plastic sheet idea - I actually thought someone had done it. I was wondering how you would be able to pull the plastic out from under all that water - or if you went underwater and cut it in half or something.
    Are you saying no one has pulled it off?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Scottsdale, Arizona
    Quote Originally Posted by Simmons99
    no no no .... plenty have done it .. It's just never been done in Texas before
    Steve will update us on his progress .
    Northern Kentucky
    ... I was wondering how you would be able to pull the plastic out from under all that water - ...
    After you have finished, you would only need to push the plastic down the wall to let the water on top start to get behind. Then the plastic would just be in the water, imagine a sunken solar cover, and you could haul it out.
    ~Grace
    Scottsdale, Arizona
    I'm thinking you should give it a shot.. It's the best way to prevent cracking of the plaster...
    Northern Kentucky
    Quote Originally Posted by Steve #1
    Like a giant bucket of water balloons!!!
    ~Grace
  1. Day 1, where to start?
    By sturev in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2010, 05:34 PM
  2. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  3. Where do I start first?
    By jen in tx2 in forum Dealing with Algae & Slime
    Last Post: 09-10-2009, 11:54 PM
  4. Help - where to start?
    By kevinm in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-01-2006, 07:05 PM
  5. My Start-up. What do you think?
    By Allora in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 08:22 PM
