Results 1 to 10 of 41
Thread: Where to start?
    Scottsdale, Arizona
    Default Re: Where to start?
    BTW ... welcome to the site Steve
    now get busy, you have some work to do ..
    Make sure the tarp is big enough to cover the sides as the water drops and also that you match the flow of water being pumped out as close as possible to the flow of water being replaced. The 'others' that have done this found that they would have to turn off the pump for a while to let the hose catch up if the pump they rented did not have the variable flow valve.. .
