Results 1 to 10 of 11
Thread: Solarattic Pool Heater
    Jul 2006
    Default Solarattic Pool Heater
    Is there anyone using this type of heater or have inquired about? It sounds like a great idea. http://www.solarattic.com/pools.htm
    mas985's Avatar
    Pleasanton, CA
    Default Re: Solarattic Pool Heater
    I got a quote from one and talked with the rep. A couple of issues resulted in the discussion.
    First, it was only slightly cheaper then roof top solar.
    Second, having water in the attic is not very appealing despite all of the assurances. What if it did spring a leak. A simple pan to catch the water is not enough given the pressure the water is under.
    Third, the rep told me that it was not as efficient with tile roofs since the attic does not get as hot. He only recommends them with composite roofs.
    So I went with roof top solar.
    Mark
    Poughquag, New York, USA.
    I talked to the manufacturer last year. They try very hard to sell you on it once you contact them. I did not buy, went with rooftop solar instead.
    I just couldn't find enough info or opinions on the web to make me feel comfortable that it would work. Another reason I didn't was a discussion I saw somewhere about it that talked about the basically finite amount of heat that is actually trapped in your attic compared to the amount of heat available to solar panels. My final reason was that I really wasn't comfortable having a 2" pipe pushing 30 gpm or so into my attic, possibly breaking!
    karrde97 is offline Registered+ Thread Analyst karrde97 0
    Peoria, IL
    I would be interested in this too. Electricity in Illinois is going up 40% next year. Gas vs elec is almost becoming moot. I need something for the cooler days to get up to mid 80's. I'd like something that works and is economical.
    21' AG 48" AquaLeader
    Central Illinois
    Peoria, IL
    Just saw the other posts that went up while I was 2 finger typing. Excellent point about the water line in the attic. Not going to happen in my house. What's the difference between roof top solar and the panels that sit on the ground? What's a good online place to shop for these?
    Central Illinois
    Jul 2006
    Most houses I know has waterlines running in their attic space. I know it's just another risk. I was hoping someone has one in service because I have any ideal situation for something like this. My water temp is between 82 - 85 in the middle of summer and it would be great to use it for cooling down the attice hence save on running the A/C.
    Talk to Ken at powermat.com he really knows his stuff and can explain why panels are better.
    Its not about heat it is energy. Once your attic cools what is the recovery time? Especially late and early in the day and year.
    How about some type of AC unit that uses your pool water to absorb heat, anything like that out there?
    Someone on the site uses small heats pump to constantly add cool to house and heat to the pool. Sounds like a good set up but I don't know anything about what they are using for equipment. Anyone?
    gg
    I did look at them and they are INSANELY expensive for what you get. I think alternate heating systems are probably in order, like water-cooling a/c condensers rather than air cooling them and using the pool water for the cooling.
    I like the idea but the cost and the risk is too high for me.
    Peoria, IL
    We installed Geo-Thermal heating/cooling in our new house. I talked with them about using it to heat the pool. It could be done. For an extra $8,000. Wasn't worth it for a 21' AG. I did see somewhere(here?) where someone put in a small Geo-Thermal like system just for the pool. I have no natural gas supply to my house so my option is electrical or non-electrical. I need something because the water's ~80F when the air is nice enough to swim. We don't get to use the pool enough because of this.
    Central Illinois
    What about this
    Brian
  1. Pool Heater
    By tippywanknobi in forum Pool Equipment & Operations
    Last Post: 12-05-2012, 04:23 PM
  2. I need a pool heater!
    By ds_girl in forum Pool Equipment & Operations
    Last Post: 02-01-2007, 09:57 PM
  3. solarattic.com
    By pilot in forum Pool Equipment & Operations
    Last Post: 06-11-2006, 10:56 AM
  4. best pool heater there has to be one
    By criis in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 09:52 AM
  5. Pool Heater
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 04-19-2006, 12:24 PM
