Re: Correct Pump/Filter?
Hi, Chris,
Your numbers make sense to me.
Your pump is a little too big for that filter. To get things in balance, you could get a larger filter or a smaller pump. I have had great personal success with an oversized filter so that would be my choice. If you downsize your pump down to about 35gpm or so, you'll match well with your filter but your turnover rate will be around 12 hours....still okay, but sort of on the borderline for a nicely operating system.
After saying all that, I'm a little puzzled with your 10psi filter pressure.(are you pulling water from both the skimmer and the main drain?) That's pretty low and indicates very little resistance. (i.e. you are not overdriving your filter at 10 psi) So, I guess where I am ending up is, if that filter psi is correct, I might just leave everything alone......especially since you have no water quality issues.
