Results 1 to 8 of 8
Thread: I think I'm testing my ALK/TA wrong.
    Default Re: I think I'm testing my ALK/TA wrong.
    So, are my numbers okay?
    When can I stop adding so much bleach per day? What are the figures I should have for FC, TC and CC? Appx 15,000 gallons.
    Sanford, FL
    Well TA of 200 is high - but if the water is clear and your PH is stable at a good number you are probably fine. If you have a plaster/concrete pool I would try to reduce your level.
    Look at the ALK forum - there is a sticky that tells you how to reduce your TA level.
    Chlorine looks fine, but you want to raise your chlorine level to 5ppm and then let it drop to 3ppm - but no lower.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
