Well TA of 200 is high - but if the water is clear and your PH is stable at a good number you are probably fine. If you have a plaster/concrete pool I would try to reduce your level.
Look at the ALK forum - there is a sticky that tells you how to reduce your TA level.
Chlorine looks fine, but you want to raise your chlorine level to 5ppm and then let it drop to 3ppm - but no lower.
