Closed Thread
Thread: Alternatives to water bags for cover weights?
    Ontario.
    Default Alternatives to water bags for cover weights?
    Does anyone have alternatives to using water bags to weigh down their winter covers? I really don't like the water bags. I find they are expensive, don't last more than two winters and are a pain to empty in the spring.
    I've used some leftover retaining wall blocks to supplement them, but keeping enough around to fully secure a cover for a 16x32 pool isn't very practical. Love to hear about what people use instead of bags.
    Thanks.
    Indiana.
    Default Re: Alternatives to water bags for cover weights?
    There are plastic boxes available that would think would be better. Don't use anything you don't want in your pool. The blocks could be pulled in if the water level drops or something heavy blows onto the cover.
    http://www.intheswim.com/Winter-Pool...e-Aqua-Blocks/
    some people simply use sandbags.
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Quote Originally Posted by JohnT
    And I'm here to tell you how true it is. I started my season this year with a cold swim in the deep end to fish out 10 8x12 inch pavers that had gotten pulled in when the wind came up and off went the cover. Also got to try my patching skills on two small (thankfully) holes in the liner.
    What'd I know, that's how the pool came when we bought the house.
    C.
    IL.
    Quote Originally Posted by ChuckD
    C.
    Same here, only insert cement block ripped a 6' long gash in the liner on it's way down and we lost 2/3 of our water and the liner was un-repairable...
Closed Thread
  1. How do you clean you water bags?
    By poolbee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2007, 11:55 PM
  2. The .99 water bags
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 04-02-2007, 11:18 PM
  3. How to use Water Bags?
    By Tillysaint in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-11-2006, 08:42 PM
  4. Step weights
    By AnnaK in forum Above-Ground Pool Construction & Repair
    Last Post: 08-07-2006, 12:17 PM
  5. Cinder blocks as weights
    By TimWillin2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-28-2006, 03:46 PM
