Closed Thread
Thread: What to look for at end of 1 year warranty
    mkelley is offline Registered+ Thread Analyst mkelley 0
    Default What to look for at end of 1 year warranty
    My pool is nearing the end of the year warranty (I think the basic structure has a longer warranty, but this is on all the equipment and anything not covered in that structure warranty) and I'm wondering what I should be looking for.
    Everything seems to work just fine, the water is still sparkling and clear, and I've had no issues. It has a diamond-rite (sp?) surface, Aqualink remote digital controls, salt-chlorinator and in-floor cleaning system (which works fantastically -- I only vaccum about once a month and don't really *need* to do even that). I've cleaned the filter a couple of times and the pool always seems to need acid (but nothing else) but other than that the chemistry and water are pretty much fantastic (I did have some green algea but a gallon or two or bleach cleaned it right up, and it was only a couple of spots in the spa).
    About the only thing I've noted are some hairline cracks in the decking (our decking extends about 20 feet all around the pool). I'm going to guess I have to live with those (we live in Florida so freezing water won't be an issue with them, and to repair they'd practically have to dig up the whole patio).
    So... anything else I should be checking?
    Sanford, FL
    Default Re: What to look for at end of 1 year warranty
    Check for leaks - you can do a simple test by filling a bucket of water to the same height as the water level on one of the steps. This way you can determine over a day or two if the water in the pool is dropping faster than the water in the bucket - if it is you have a leak.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
Closed Thread
