Thread: Hayward Color Logic
    captainx is offline ** No working email address ** captainx 0
    Default Hayward Color Logic
    I have a silly question, that hopefully has an easy answer. We have three Hayward Color Logic lights installed in our (nightmare) pool and when we finally filled the pool and got them to work two are on one color but the third is on another.
    Is there a way to get them into sync?
    Much thanks!!!
    mas985's Avatar
    Pleasanton, CA
    Default Re: Hayward Color Logic
    I think they are similar to SAMs which I have. After you turn them on, turn them off and back on again within a second and they should autosync. If not try it again.
    It should be in the manual. If you don't have a manual, you can find one on haywardnet.com.
    Mark
  1. Color Splash / Color Logic Replacement LED Ligths
    By shutitdown in forum Pool Equipment & Operations
    Last Post: 06-22-2012, 01:59 AM
  2. Hayward Color Logic lights... FAIL!
    By beantown in forum Pool Equipment & Operations
    Last Post: 08-29-2010, 11:11 PM
  3. Hayward Color Logic Problem
    By tommy_b in forum In-Ground Pool Construction and Repair
    Last Post: 05-11-2007, 03:08 PM
  4. Jazz Light ??? SAM Lights??? Color Logic???
    By Jinx32 in forum Pool Equipment & Operations
    Last Post: 07-18-2006, 04:18 PM
  5. Color Logic vs Sam Light
    Last Post: 07-13-2006, 09:55 AM
