Thread: What am I doing wrong?
    Tennessee
    Default Re: What am I doing wrong?
    Here are a few things to think about for your pH problem
    Did you test your fill water for pH and ALK when you refilled your pool?
    What test methods do you use?
    Any fountains in the pool?
    Does your water return break the surface?
    When are you testing?
    Where in the pool are you testing?
    I found by testing next to the return my pH was higher. I am in the process of dropping my ALK slowly and checking for pH raise. Higher ALK in my pool caused my pH to run up every week.
    Jul 2006
    Still looking for answers
    Test water was 7.8
    I am testing with a drops tester...not perfect but repeatable results
    No fountains
    Return water has not been aerating the water generally
    I test in the morning generally
    I test from all over and I use a large baster to draw water from about 15-18" under water
    The pool is presently not covered
    I have heard and read that shocking the water is the way to go, but i dont understand it since the bleach has a high ph.
    duraleigh Guest
    Test water was 7.8
    Do you mean fill water?
