Results 1 to 10 of 17
Thread: Need to kill ants
    mbar's Avatar
    Ashland, PA
    Default Re: Need to kill ants
    Here is a post you may find interesting:
    http://www.poolforum.com/pf2/showthr...highlight=ants
    Northeast PA
    Northern Kentucky
    Another folk remedy is cornmeal... sprinkle it around, and the ants will eat it and feed it to the queen. The cornmeal will swell in the ants, and BOOM! little ant bombs!
    I am not totally sure of the effectivness of this method, but sounds good in theory, and no harm done if it does not work. No poison lying around to harm pets or kiddos, either!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Jennifer: We're just north of SA in the Boerne area. I have fireants. I've just been going around the pool with that stinky, expensive fire ant bait... but I'm sure they're still under the pool (and the LOVE the pump). Was talking to my DH about it, who is from a family of pest control folks... he says to find a pest control company that does termite treatments. They have big wands that they can put into the ground and get underneath the pool. I don't know if the termite poison works for ants, but it should and if not, they can probably use something else... but their equipment is the most likely to get up underneath your pool and into the ground and run those guys out. With this drought we're in, everything wants to get to that water. I'd try to kill the one's under the pool and then maybe set something up away from the pool with water in it to attract their friends away from the pool.
    HTH.
    Lori
    DE or the pesticide derivative thereof - sprinkle it around the pool , it will cut their exoscletal structure, infection sets in.
    N.E. TX
    Not to hijack, but does anyone know what else DE will kill? I have to continually kill grub worms. Not only are they trouble by them selves, the gophers love them. I would love to use DE for ants and grubs.
    Thanks in advance,
    Brad
    27,000 IG Vinyl
    Aquarite SWG
    Still Learning Everyday
    DE will help kill just about every exoskeletal organism, by exoskeletal, they mean the skeleton is on the Outside like an ant, earwig, potato bug, beetles. What it does is pierce or cut the skeleton, this allows dirt and other things to get into teh cut and infect it, in most cases causing death. They make insect powder that is 95% de and 5% some sort of toxin, this is supposed to ensure the cut gets infected by means of the toxin. It costs a LOT more than just DE, and supposedly, from people who have tried both ways, it really doesn't do much more, likely, the cut plus the dirt environment pretty much guarantee that infection sets in anyways. I had no problems getting rid of an anthill under my hose reel this summer wiuth straight DE.
    As for grubs, because they also have a "skeletal type skin" protecting them on the outside, DE will also be effective - actually, grub killer is the same as ant killer etc.
    DE does to bugs what broken glass would do to you.
    jenpen400 Guest
    Ok now they have done it! while I was patching a hole they got my beer! DE Borax, and corn meal. BTW I would avoid using any petrolium based products in contact with the liner as they can damage it.
    Thanks again
    jennifer
    Country Living in Comal Co., Tx
    Quote Originally Posted by BlueBlobTX
    HTH.
    Lori
    Howdy neighbor!
    We're outside of San Marcos, between SA and Austin. We have (or had) fire ants, leaf-cutters, sweet-eating, carpenter ants, flying ants....and all their relatives.....lol
    A troubling fact surfaced during my research for building our pool: Carpenter ants (and possibly fire ants) EAT "flex-hose" .....the hose that many PB use to connect the drains to the pumps!
    Here in Texas, a lot of pools have to be dug into bedrock, so replacing a cheap piece of flex hose may cost a large percentage of the total pool cost
    So naturally, we demanded that no flex hose be used and Schedule 40 pvc be used in all pool plumbing.
    About the ants........I don't want to bore anyone with my LONG multistate battle with the warrior class, but I've tried ALL the suggestions above. DE, borax, Grants for ants (good for sweet eaters), boiling water, Terro, etc.
    Recently, I found http://doityourselfpestcontrol.com/ and started buying the 1lb. tubs of Cypermethrin 40% based insecticide. Unlike the Home Depot varieties, this stuff WORKS!.......lol (it's relatively non-toxic to humans, but can't be used on food surfaces........I don't use it INSIDE at all)
    It's under the brand name of Cyper WP, and can also be found on Ebay for slightly less, but more importantly.....You don't have to give your credit card number to an unknown website and you can pay through Paypal.
    But take a look at the website. Tremendous info about all kinds of pest problems!
    hth,
    STS
    19,000 gal IG freeform pool - 14'X40'
    Raised spa with "island" table
    Hayward automation with SWG
    Tristar pumps -circulation, spa, waterfalls
    Hayward Phantom pool cleaner - Love that Phantom!
    Rheem/Raypak Pool Heat pump
    Ben's PS234 kit
    jenpen400 Guest
    Thanks all, we are starting to make headway we sprayed an insecticide around the pool to knock down population now we are treating with bait to finish them off. One more hole to patch. Oh and they are leaving my beer alone now.
    Fingers crossed
    jennifer
