When to stop shocking?
How do you know when the algae is dead and gone forever.
A healthy pool should have
-Clear water,
-Chlorine levels that hold overnight,
-0cc, and
-No algae forming on pool floor.
Do I wait for all the above before lowering the chlorine from shock levels, or is one or two sufficient?
I can't trust my cc levels because I'm using dilution method
(1 part pool water : 4 distilled) and multiplying readings by 5.
Therefore I wouldn't notice
Additionally, I know the advantages of vacuuming to waste, but given the time to vacuum the entire pool, I would loose too much water. While not ideal, is it OK to vacuum to filter, and then backwash?
Once the algae is cleared would there be a benefit to dumping bleach directly into the filter and letting it sit for a while to kill off any algae remaing from backwash?
Carl Schnurr
96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
