Thread: Algae again?
    Guelph, ON, Canada.
    Default Algae again?
    Three weeks ago, upon return from a two week vacation, I returned to algae in my pool, which I cleared up thanks to reading up on this forum.
    Last week I was away from the house for another week. Just before I left, I increased my SWG ouput to avoid a repeat of previous problem.
    Yesterday when I returned, the pool was green again.
    Before I did anything, my numbers were
    FC: 7.5
    TC: 7.5-9 (No noticeable change in colour, but I am diluting the sample to read above 5ppm so readings are not exact.
    CYA 55
    TA 100
    CH 380
    Backwash water looked relatively clean.
    So I've boosted the Chlorine up to 20ppm,
    I will monitor this 3-4 times per day, with regular brushing, vacuuming and backwash. I know I'll get this cleaned up in the next couple days.
    I have a couple questions about should I have done anything differntly.
    1)FC at 7.5, how could the algae form?
    2) Is it possible that I never completely got rid of it? even though my numbers were good, and the water looked clear.
    3) I thought it could be repeated because of contaminated sand in my filter. So I drained the filter below the sand line. It looked pretty good to me, but I did notice that the first gallon or so of water was greenish, and then the remaider of the drained water was clean.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
    Default Re: Algae again?
    I'm guessing that you never killed it off completely the first time, although that's pretty much a WAG....but the fact that you had greenish water draining out of your filter tells me you still had living algae it there. This time keep your shock levels up for a couple of days or so after your water clears and it should get it all this time.
    Not that I can help explain anything , but what was your pH? If it was on the high side, maybe FC of 7.5 isn't enough.
    If it's mustard algae, it is entirely possible as i've learned first hand, 15 ppm only slows it down.
    Check here for a visual comparison
    http://www.poolforum.com/pf2/showthr...?t=5612&page=2
